Todd Humphreys
- May 12, 2004
- 81
I have a 1982 Johnson 75 hp, and the last time I was out the motor had a really bad miss at idle. A couple of days later I checked the plugs and the top two was rusted. I pulled the water jacket and head see what the inside was like. No. 1 & 2 piston had salt baked on top of them and the third had alot of play in the cylinder. Head gasket was to blame for the water leak. After striping the motor and pulling the pistons, I encountered that pistons no. 2 & 3 were scored and cylinder 3 had a bad scratch the entire length of piston travel. Upon closer inspection of the pistons and rings, on pistons 2 & 3 the pins that keep the rings from rotating were broken off, one was stuck in the ring grove and the other missing. I think that was the culprit of the bad scratch in cylinder 3. Is this common for the pins to break off and cause this kind of damage, or did something else such as carbon or lack of lubrication cause this to happen???
