Ok here is the deal. I have a 1993 Evin 175HP. I took it out on the lake Friday Ran Great. Saturday put boat in the water loaded up went to a little island to set up camp, dropped off some people went back to pick up a couple more and on the way back at WOT the boat just shut off. Started it up idled along, gave it a little throttle it shut off again. Finally got to where we were going and anchored up. I pumped the bulb on the fuel line, fired right up but shut off once all of the fuel was out of the bulb and line. Did it again same result, it seems like I am not getting suction to keep the gas flowing? Finally got towed back in and loaded it up. When we got back to our cabin I check the coned shaped fuel filter, it was fine. I put in new plugs, check for leaks, didn't seem to find any. Put the boat back in the water Sunday Morning started right up, I idled out of the no wake, hammered it, it took off perfect, Ran it for about 10 minutes, WOT and idle speed. Thought it was fixed so we stopped to fish for a bit, maybe a half hour, started back to shore to pick up some other people, starting going and guess what same damn thing, shut off. Pumped the bulb, fired up for 2 minutes, shut off. Any Ideas? There is a connection on the front of the motor the looks like you hook an airhose to it like a tire valve stem that has a red switch, which you can eiter have up or down? When in the up position and you pump bulb gas comes out, but with it down it seals, don't know which way this should be? What else could be causing this? When I do get it restarted the and it is at idle it seems to idle fine no engine noise or anything. Any help on this situation would be greatly appreciated.
