Re: 85 JOHNSON WILL ONLY DO 12 MPH SUCKS GAS
I'm about out of ideas on this one. No way that 17 pitch prop is your problem. It may not be the ideal prop for your set-up but it isn't why you're not running right.<br />Has the lower unit been re-sealed lately. Look behind the prop at the bearing carrier. There should be a triangular cut-out on one side of the bearing carrier. That cut-out has to be at the top for exhaust gases to pass through it. See if maybe someone put it in wrong.
