Re: Keel Protectors - The Good and The Bad
The Keel Guards install easily as long as the boat's keel is exposed and not resting on a trailer roller or bunk. Prep the hull/keel as the instructions indicate, depending on the type of kit you'll need acetone or alcohol not supplied with the kit. The guard has three peel off strips going the length of the guard. First you peel off the middle strip (about two inches wide) the position it in place, then do either side, and roll with the supplied roller or a heavier duty one if you have it. Apply lots of pressure to seal well to the hull. Some brands supply a clear marine caulking to seal the entire perimeter, a good idea for brands that don't supply it. I'm going on year four and noticed some of the caulking coming off in spots, so I'll reseal this year before launch. Don't use any other products to adhere the keel guard than what is indicated in the instructions, they stay on extremely well. Like I said four years no trouble, and boat is in the water on a mooring for 5 months per year. When you're on plane it's not in the water.
