I have a 1966 Johnson 80Hp which I have just recently got running. When I started (in a barrel of water) I noticed that there was not a steady straem of water coming out of the water outlet so after ~30 sec I shut it down. I water to do a visual inspextion of the water pump/impeller . .etc but am unsure to it's exact location. I don't want to take the wrong section of the lower unit off. Do I take the bolts out at the top of the long shaft extension or the bottom?? What should I expect to see? Should be aware of anything when I take this apart?? Is there any gaskets that will need changing once I do take it apart. <br /><br />Any info on how to take this apart and what to check for in the water pump would be greatly appreciated. The motor is a 66 Johnson 80Hp V4S-18C
