briantedder
- May 13, 2004
- 2
I have a 1987 Johnson (I mix 50:1) The boat runs good at idle. The problem starts about 3-5 minutes after I am running at almost full throttle. The motor starts shaking really bad and slows down. It will run fine just above wake speeds but you cannot go any faster it just shakes and won't let you go any faster. I will then cut the motor off for about 3 minutes, then crank the motor back up and then begin to go full speed, and it does fine. <br />Last summer when I first bought the boat, It did the same thing the first time I tried the boat out, after that happen I replaced the spark plugs and it was fine until now, but I was thinking it is just a coinscience, and not the spark plugs at all?
