Hello to all,<br /><br />I have a 1989 Evinrude 150XP model 150STLCEM.<br />Looking at the back of the motor the bottom starrboard side cylinder is only reading 85lb.s of cranking compression. All other cylinders are between 105 and 115lb.s. This was done with the throttle wide open for several revolutions.<br /><br />When sqirting some oil into the troubled clylinder and running compression check again it comes up close to the others. I am thinking I have bad rings or a scored cylinder.<br /><br />I guess the next thing I should do would be to pull the head off and get the piston to bottom dead center and inspect the cylinder wall right?<br /><br />OK heres where I need some help. I would like to take the engine down and rebuild it if the block is good. I need to know the answers to the following ?'s please.<br /><br />Q1. What special tools will be required? ie... flywheel puller etc to get the engine apart and back together?<br /><br />Q2. What is the best manual(s) available to get that includes engine spec's and tollerences and disasymbly/reasymbly instructions preferably with some decent illistrations? Where do I get one from?<br /><br />Q3.I have rebuilt several auto engines, what are the main differences and "gottcha's" to look out for on a boat motor?<br /><br />Q4. I know it has no cam being a two stroke and the bearings are different. I have also heard that the pistons in this year motor do not like, or were not manufactured for use with lead free fuel, fact or fiction? Should I get all new pistons or can I just get one if one is bad and bore just the one cylinder and put all new rings in?<br /><br />Q5. I also would like to replace the water pump. What other parts should I replace while going through it?<br /><br />Q6. What should it cost to have the block bored if it needs it.<br /><br />Q7. What are some good places to get parts for decent prices.<br /><br />Sorry for the long read, but I want to get as much information ahead of time as possible. Wife will be ready to go out soon so I need to get started fast. <br /><br />Thanks A Lot!!!<br /><br />ChevyReb
