Re: Decarbing for those who need info
Good info Rick, this explains things very well, with one exception. It doesn't explain why not to use the schraeder valve on the primer on the carbed motors, I know the ficht's valve is only for fuel pressure testing, but isn't the valve on the carbed motors made for fogging and deacrbing? I have been using the schraeder valve on the primer for fogging and decarbing for years and never had a problem. Is it just that the decarb works better through the carbs themselves or is it actually bad to run decarb through the valve? The reason I have always done it this way is because they make engine tuner with the valve fitting on it, so I just assumed that you could use the valve, maybe I won't this season. Just wanted to know the reason why. Thanks alot, Mike.
