1978 70HP Johnson, I did a complete carb rebuild, soaked overnight and replaced all jets screws. When I took it out to the lake the first time it ran great, two days later I take it out and it can barely even idle without stalling out. It would continually start and barely idle, and if you attempted to give it any power it would die quickly. As I was giving it throttle I tried to pump the fuel bulb at the same time to make sure it was getting enough gas and it would still die out. The engine then started to pick up and gain power after about two hours of running at low speeds but I noticed gas dripping out of the motor. Upon opening the outboard cover I saw one of the fuel lines leading from the middle carb to the T-connector that connects to the other carbs was loose and gas was dripping everywhere. Earlier in the day I took off the engine cover to examine everything a few times and there wasn't a fuel leak, I then fixed the fuel leak and my engine was back to the same problem. My question is, Any possible ideas why this leak would help the engine gain power which it hadn't been able to do all day? Also, At the end of the day I checked my spark plugs, sometime after taking off the top plug, some oil leaked out of the top cylinder hole, not much but enough to run down the engine past my second plug, Is this anything to be worried about?
