tony_cliffy
- Mar 19, 2003
- 182
Hello!<br /><br />I am at that part of my break-in period for my new 2004 Johnson 115HP 4-stroke where I was advised to go to full throttle for brief periods of time. But as I increased my speed towards full throttle the engine started missing or possibly modulating the output via rev limiter. I do not have a tach installed yet (I will soon) so I do not know my RPM's, but the boat speed was only 33 MPH and everyone says this boat should do far more than that with the 115HP engine.<br /><br />It does *not* sound like cavitation. Do you think I am hitting a rev limiter or some other RPM-limiting feature? My little engine book does not describe a rev limiter feature. No alarms are sounding, the engine has plenty of oil and waterflow and otherwise works fine. But I feel the engine is preventing me from reaching max speed.<br /><br />I have varied the degree of trim and it appears to happen regardless of trim setting. Also, I am approaching full throttle by slowly increasing speed, not by performing a "hole shot." For example, I am cruising at 25 MPH with good stability and flat water and begin to give it more throttle until the engine starts to make this noise like a rev limiter is kicking in. I immediately back out of it.<br /><br />I do not know what prop is on it other than my reputable dealer completely installed this engine and chose the prop based upon his knowledge of my boat.<br /><br />The engine is mounted to a 20' Crestliner aluminum center console which is a light boat (@850 lbs) with only a moderate V in front and fairly flat along most of the bottom.<br /><br />Thanks!
