Recently I went to change my lower unit oil and it was foamy with water. I had the unit resealed sring of 2002. I put a pressure test on the unit like the manual said. The unit is holding at 18psi for the last hour.Is there some way that water could still get into the unit with it holding this kind of pressure? Could I have had to much water pressure on my earmuffs when I was running the motor in my driveway? Should I reseal it anyway? It seems like a waste if its holding pressure.Any help will be appreciated. Birdman
