I have a 1978 70hp johnson. This past weekend I took apart my carbs and installed the rebuilt kit. I put the carbs back on the boat and it is still flooding. I set the floats correctly but I wasn't sure how to set the high and low speed screws or if my carb even has them. My manual is a piece of junk and doesn't explain anything. when I took out the screw at the top of the carb there was a little plug in the back that was backed all the way in. You can see a picture of this on the lync below. I removed the screw at the bottom of the float bowl and looked inside there and saw something in the back that almost looked like what came out of the top screw hole but I was unable to get it out with a small screwdriver. What are these? Does anyone know how to set my carb from not flooding? Are these screws my high and low speed settings. My manual shows that there is suppose to be some needle coming out of the top. I dont have this. All I have is what is shown in the picute in the bottom lync. This boat is driving me insane, I've had it for one month and every time i've taken it out it starts up fine and then wont start again. Any information on how to set this carb would be wonderful!<br /><br />you may have to copy all the lync to the address bar because it is two lines long and some of it was cut off.<br /><br /> http://www.villagephotos.com/pubbrowse.asp?selected=584335
