My rude is cutting out on the bottom cylinder when I advance the throttle. Just before planning speed I lose the bottom cylinder. It has a little fuel on it when I check the plug. At low speed it will run on either plug with the other wire pulled. When I am running it on just the lower cylinder (top wire pulled) it will run till half speed then stops suddenly (not intermitantly). Will run forever on just the top one, or both at low speed.<br />Should I change the mag first, or have the carb cleaned?<br />Thanks, Ben
