Re: 87 60 HP Evenrude Grinding going into reverse
Follow Hooty's procedure and confirm that the engine will shift fully into reverse using the shift arm.If engine isn't running while performing the shift arm test ,make sure that you spin the prop while shifting.If engine is running ,be careful around the prop. If the shift arm test checks out and lower unit seems to be fully engaging into forward and reverse gears ,place the shift arm in the neutral position and note whether the shift cable clevis is aligned with the hole in the shift arm.If not,with the throttle control lever in the neutral position, adjust the shift cable trunion until the holes are aligned and reinsert pin.<br /><br />If this adjustment procedure doesn't work ,you likely have a worn shift dawg or reverse gear lobes are worn causing it to slip out of engagement.Good luck.
