MoneyPit03
- Sep 15, 2003
- 6
Great site folks.<br /><br />I guess that I am a sucker for hard luck cases. I recently purchased an '86 Robalo 2120 with an '86 225 Evinrude. From what I can tell, the model number is 396684RPH (Tag on transom is not legible.<br /><br />Pulled the power pack and found a mess of black goo beneath on the starboard side of the engine. From what I can tell, the power pack is fried along with the harness and switch assembly that temporarily cuts ignition as the tranny is put in gear. There is a cooling device beneath the power pack that was completely melted (mounts to the block and inserts cooling fins into the water cavity). Is this part of the stator? It appears that there are not any quick disconnects beneath the fly wheel associated with this thing. <br /><br />There is an open ended wire that runs from the starting solenoid to this general area. I am assuming that it just inserted into the cooling device since I could not find any other place for it to go.<br /><br />Any suggestions on what caused this to happen? Also, what is the purpose of the wire from the solenoid. <br /><br />Additionally, having a fuel pressure issue when the engine had a load. Ran fine at idle. I assume it is because of the power pack issue. Any suggestions most welcomed.
