Re: Fuel guage stopped working ????
Neil - Most marine supply shops carry generic senders. They come with detail instructions. The screw pattern for the sender is an industry standard so it is a simple job. The instructions will tell you how to calibrate the sender to your tank. <br /><br />You can also call the manufacturer of your tank and get their recommendation specific for your tank. There is a data plate, usually close to the sender of filler neck, that gives the name of the manufacturer, the model of the tank and the capacity. I went this route a couple of years ago and am more comfortable that the reading is accurate.
