I bought another tachometer. This one had a terminal for Evinrude/Johnson motors but I didn't fare much better. I went with what was there originally which was the power switch sends the 12 volts to the IGN. terminal. Ground goes to GRD and I used the EVN/JHN terminal that was an extra on the Teleflex in addition to the normal SEND that I left unhooked. <br /><br />I get a tiny reaction to turning the 12 Volt on. Just a shake of the needle. Motor doesn't make the RPM's do anything. Sits on zero. Traced the wire back to the terminal block that I've got going to the EVN/JHN terminal. That was the wire that went to the sender on the original 2 wire tachometer. I did a continuity test and the wire ohmed out to the terminal. I think it is the 4th one down from the top. I believe it is still Gray when it gets there. (Thicker than it was.) What should I get for voltage there if I just hook a meter between ground and the gray wire going to the terminal? I think I was told to put it on AC instead of DC. <br /><br />Any help would be appreciated...<br /><br />Thanks... Gary
