I have an OMC 115 Turbo Jet in a 14 ft Four Winns Fling. The motor works fine when I am running the boat and cruising at moderate and high speed. If I slow down to an idle or very slow speed the engine will over heat. I have completely flushed the cooling system and disassembled all the hoses and I cannot find any problem. I replaced the spring and ball check valve on the out drive. I replaced the thermostats and the pressure relief valves. What should I do next ???
