I just purchased a 98 40hp johnson outboard on a whaler 13 dauntless. i had it tuned up at the dealer. The first time I put it in the water I noticed that when you advance the throttle to the first detent after neutral the motor has some vibration and chatter. It doesn't sound like gears grinding. This happens in both forward and reverse. As soon as you push the throttle further forward even only slightly as rpms advance the vibration/chattering goes away and the motor runs great. The lower unit oil was changed and the motor only has about 60-70 hours on it. Is this usual for this motor?
