I have purchased a used '63 40 HP Johnson.<br />Problem is it will not pump water. I have replaced all seals in lower end and put a new impeller in it. The motor had been taken apart by the previous owner and sold as a "Running" motor. However when I got home with it I realized that the lower end had only 2 of the 7 bolts holding it to the top end. The Model Number is RDSL 25D The serial number is 2382455.<br /><br />If anyone has a Drawing that they could send me to see if anything is missing in the lower end, (Water Pump) I would appreciate it.
