Hello All<br /><br /> I am having a problem getting the Propeller Shaft out of the lower unit.<br /><br />I have an 86 Johnson 60 HP VRO on my 88-bumble bee v154 bass boat that I paid $ 650.00 for.<br />The model # is J60TLCD<br /><br /> I did an over haul on the power head with no problem. Changed carb gaskets float, new holes, cleaned fuel tank, etc. It starts and runs great, but I see that the propeller shaft is bent so I am trying to removal it to get repaired. There was no water in the lower unit, which is a plus.<br /><br />1) Do I have to remove the lower unit to get the shaft out?<br />2) I have removed the shaft housing and the snap rings and the washer.
