Re: 55 hp johnson
The model number means 55hp, electric start long, 1969. Factory manuals are the best, but the Cole (Seloc) manual for 1958-72 50-125hp is a pretty good alternative. <br /><br />Those motors are pretty good. The lower unit is hydro-electric, which is different and in my opinion much less troublesome than the earlier magnetic clutch ones. For one thing if it breaks, it stays in forward so you can get back to the dock - the earlier ones stuck in neutral. <br /><br />You can try spraying wD40 in the spark plug holes, and turning (not too hard) the flywheel with a socket. Turn the flywheel clockwise (looking down from the top) so you don't mess up your water pump impeller. For legal reasons, I need to WARN you that the motor may start at this point, causing you serious injury or death.<br /><br />Be aware that the hydroelectric lower units may 'fake' a lock up. I've had this happen twice, when turning the flywheel or prop with no 12V to the motor. Not sure exactly what happens or even how to make it happen, but always clears when you apply voltage to the lower unit control wires.
