Re: 86 evinrude 175 V6 rpms racing upon startup
Are the control cables are connected to the linkages properly?The linkage's and engine timing must be synchronized.Control cable length must be properly adjusted before operation.Other than that you may have a bad vacuum leak somewhere.Have you installed new controls or cables on the motor?<br />Go over the motor under the hood and make sure everything looks normal,and all connected.
