I have a 1975 25hp evinrude outboard, I have been having some misfire problems. I went to change out the plugs and discovered that the spark plug threads were stripped, so I pulled the head and am in the process of getting the helicoil installed. Also, when I was pulling the head I noticed the bottom 2 head bolts were looser than the others causing fuel leakage. When I got the head off I noticed the top cylinder was very clean with little carbon build up, but the lower cylinder was considerably more gunked up that the top. Also, the plugs that were in it were Champion L77LC4, which my manual calls for JC4. Would the loose lower head bolts, plugs, and the stripped plug threads cause a misfire? Any help would be wonderful.
