badasselectric
- Mar 28, 2003
- 64
Re: 89 Tracker Evinrude 40 Hp ; prop or engine?
Checked reeds,they looked fine. Ordered carb rebuild kits, cleaned I carb the other is soaking right now. I cranked the engine with the mix fuel line in a bucket and it pumped like crazy. I rigged up a spark tester and checked the spark on both cylinders, they both jumped a 7/16" gap and looked strong. The advance plate moves freely from stop to stop. Checked the compression again and got 130 psi on both cylinders. Also installed 2 new QL78YC plugs gapped at .030".<br /><br /> Now here is where I'm at going back to internal combustion engine basics you need 4 things to make one run. right?<br /><br /> 1. compression- got it.<br /> 2. spark- got it.<br /> 3. air- got it.<br /> 4. fuel- I'm not sure about this one, but when I get done with the carbs I should have it.<br /><br /> I,m thinking of cleaning my pistol while I'm cleaning these carbs just in case I need it to put this motor out of its misery.
