COYOTE54
- Mar 22, 2003
- 23
Hi all,<br /><br />I just purchased a used boat with a late '80's Evinrude E40TTLCCS. It starts fine, idles fine, wants to die when placed into gear (either reverse or neutral), seems to run fine wide open if you can goose it a little when putting it into gear to keep it from dying, won't stay running when returning to idle while engaged in gear unless I keep hitting the choke button.<br /><br />Mechanic said that the ignition advance module is missing, which caused the timing to advance too much at full throttle and now I need a $2000 dollar overhaul because #1 cylinder has a knock.<br /><br />Does all of this sound right? I thought I just needed a tuneup.<br /><br />How much damage could have been done to the number 1 hole? Could I get by with just replacing a piston?<br /><br />Thanks.<br />Tim
