I pulled the gas line from the engine and let it burn the gas from the carb. Let it stand for 5 months. Started it 5 months later ... NEW gas .. RPM only reached 4100 when it used to get 5500.<br /><br />Engine uses a gas / oil mix.<br /><br />Pulled carbs and cleaned them with carb cleaner and compressed air. Visually inspected all jets and ait holes.<br /><br />Inspected Fuel Pump - ok.<br /><br />Check Ignition ... all 4 cyl's spark ... checked voltage going to coils - all at 200v per spec.<br /><br />Still engine only get 4100 rpm.<br /><br />While running wide open .. pressing the key in to choke the engine (this activates a selenoid which dumps gas directly into the carb throats) ... RPM increases to 4800.<br /><br />I have taken the carbs apart twice looking for something. No Linkage changes ... no prop changes.<br /><br />Suggestions.
