1994 Evinrude 225 with VRO. Motor has not been run for several months. Decided to drain fuel tank and replace with fresh gas before starting. Disconnected fuel line at the inline filter (just before fuel pump) and started pumping bulb to drain tank. Instead of gas I got what looked like pure 2 stroke oil (no I did not disconnect the oil line). After several pumps the oil was gone and gas began coming out. I visited local marine dealer and the mechanic said that he had seen this many times this spring. Mechanic said the check valve in VRO goes bad and the 2 cycle oil will drain back down the fuel line. People will pump bulb and fill carbs with 2 stroke oil. Then engine will not start or will be very hard to start. Mechanic claims most of the engines with this problem are around same year model as mine (1994). Mechanic said he has replaced several VRO's this year because of this problem. I have since disconnected the VRO and mix gas in tank. <br /><br />Has anyone else seen this? This could explain why some engines smoke a lot at first start up?
