Good point!! <br /><br />Then you have to paint a new name over it.Originally posted by djvan:<br /> If name has been on a while, there is a possability that the gel coat under won't be faded and the rest of the boat maybe. So the name may still show after removed.<br /><br />DougV>
Thanx for all that replied I got the name off do not know what it was painted with but wadda b***h to get off I tried aciton oven cleaner finnaly had to go the wet sand route came up quite well, just keeped sanding with water and a fine sanding pad and then went over the whole area again with 1500 although I do not think it was required. but it is off and also washed off the bottom. I had her out on Saturday.<br />Alex<br />PS you can really see what needs cleaning now.Originally posted by Mdude:<br /> That's great. But all kidding aside, if the name has been painted on the boat in "One Shot Enamel," you can take it off with oven cleaner.
What about trim tape / boot stripe ???Originally posted by Mdude:<br /> That's great. But all kidding aside, if the name has been painted on the boat in "One Shot Enamel," you can take it off with oven cleaner.
I ready took the all stripes off her not sure whether I like them off or on But the next thing is to get the Renken decals made took pics Do the art work and re print them.<br />Any one know what that Font is I have seen it before just cant remember where.<br />Anyway the plan is to clean her up fix any boo boos like the one from the front roller. I have noticed a lot of what look like pits in the gel, know this is not good. Wondering if I should paint the bottom if I do what would be a good paint keep in mind that it will be rolled on around a trailer. So any advice on this would be helpful I have a jack so I can move it up off the trailer a bit this all below the water line the rest is perfect other then real dirty 25 years of out door life can do that. There are lots around me who think hell it running and it doesnt leak Hava blast but I say have fun and work as well only cost me time for the most part anyway.<br /><br />AlexOriginally posted by KaGee:<br />What about trim tape / boot stripe ???Originally posted by Mdude:<br /> That's great. But all kidding aside, if the name has been painted on the boat in "One Shot Enamel," you can take it off with oven cleaner.
