Re: flat bottom motor question?
It depends. You would use a lower pitch(lower gear) and maybe bigger diameter(grab more water if it fits on motor or more blades) for a bigger boat depending on what you can get for it. Most OBs have limited diameters to choose from. But trolling was likely slow or mid speed on this motor and it might not have mattered. They may have put a smaller prop on and then it would rev a lot at high speed, when not cavitating (of course) on your little boat. I doubt they propped it for max performance on the big boat just to troll with, as most people troll slow. Who wants to troll with a 4hp screaming away back there? The prop change would have little effect until the 4hp was run at around 3/4 throttle and above on the big boat.<br /><br />Call the dealer and ask what it should be. The size ought to be on the side of the prop or the hub end, like under the nut. If it was too small it would rev up and be at top speed quickly on your boat, and idle down to very slow speeds. Have to get the air out of there first to find out how it runs.
