Re: 1979 200 hp johnson runs good then bogs
Howdy, DS.<br /><br />You are probably dropping a cylinder or two (or 3?).<br /><br />This could be a carb getting too little fuel. Low float setting? Could also be a failing fuel pump that can't keep up with consumption.<br /><br />More likely it is an intermittent loss of spark to part of your cyls. Pull the cover and try it without. The cover could be moving a wire where it is able to short to the block intermittently, or it could be allowing an electronic part to warm up to a partial heat failure.<br /><br />Let us know what you find.
