Re: 1985 9.9 Johnson with leaky grommet
Ok, here goes! The proper way to remove the powerhead, versus the way OMC's service manual says to do it!! Do not remove the air silencer, carb, mount bolts or any of that..... Here's how. <br />Remove the gearcase. Take off the tiller handle OR take out the throttle shaft from the tiller handle. (later units had a throttle cable, in which case you only need to remove the handle from the bracket, the whole handle would stay with the powerhead and pan). Next, with a small set of snap ring pliers, remove the snap ring that holds the "next" throttle gear and it's small, about 3" long shaft. That would be the throttle gear inside the steering bracket that "butts" up against the throttle shaft on the tiller! Got it?? (again, the later throttle cable models didn't have this additional geat and shaft). Now remove the six powerhead bolts. The two aft ones are slightly longer than the other four. Take a fairly large prybar or screwdriver and place it between the motor pan and the bracket that the tiller arm attaches to. (the steering bracket). Give it a quick "twist" or pry, and you will seperate the powerhead gasket (and the powerhead from the exhust housing. Grab the motor pan. Lift straight up (clearing the water-tube and shift shaft) and place the engine on it's flywheel. You now can service the inner exhust tuner, water-tube, grommett etc... <br />Putting it back is the same but for the following. put a rubber band around the water tube and exhust tuner. Oh, did you inspect the upper mounts???? Stand next to the powerhead so that as you grab and rotate it, you will be on the port side of it in it's normal position. If you look carefully, you can see between the pan and block and down to the water tube hole inside the exhust housing as you lower the powerhead down inside . This way you can see the tube and not damage it as you lower the powerhead. Also, it helps if a friend takes a thin, long screwdriver up inside the hole in the exhust housing for the tube. this way you can guide the tube throught the hole. Lower the powerhead and you can situate the shift rob into it's hole also. Just worry about the water-tube first. Then reassemble as you took it all off.
