Re: Shore Power problem
I think it is important your reverse polarity indicator is flashing when you flip the main breaker off.<br /><br />Yes, a lot of AC stuff will work with reverse polarity, some wont. And yes, regardless of polarity the volts will read the same. Also know that unless you are using a voltmeter that is true rms your AC voltage reading will be higher than expected, not really the voltage that you have, but I doubt thats your problem if you are reading 120v.<br /><br />You can check for polarity with your voltmeter. At any wall plug/receptacle, the inlet for the smaller blade should be hot. Stick the red lead of your meter in there. The inlet for the larger blade is neutral, stick the black lead in there. It should read 120v (or there about) regardless of polarity. Leave the red lead in the smaller blade inlet, remove the black lead from the larger blade inlet and stick the lead in the round hole. It should read 120v if all is well. If the reading now goes to 0 you may have reverse polarity on the AC, and you need to do one more check. Remove both leads, and then stick the red lead into the inlet for the larger blade, and the black lead into the round hole. It should read 0, or there about with some millivolts. If you get 120v you definitely have reverse polarity.<br /><br />Btw, this is how your reverse polarity indicator works. It is a common light wired upstream of the main breaker with one leg on the neutral (same as larger blade inlet) and the other leg on the safety ground (same as round hole). When everything is working, there should be near 0 volts between those two. When the polarity is revered, there will be 120v between the two and the light lights up.<br /><br />Before we get to far into this I want to know why you have a 3-pole breaker? Monitoring of the hot (black) and neutral (white) is required, i.e. a 2-pole breaker. The safety ground (green) should NEVER be run thru a breaker. Do you have your safety ground (green) going thru that breaker? The AC wiring that you have, was it factory wired? Any idea how old it is?<br /><br />Btw, a GFCI breaker has a test button and a reset button on it like a (now) common bathroom outlet does. Your main breaker should not be a GFCI breaker.<br /><br />Edit: Im thinking there is a combination of events that is happening here, and there are several possibilities for each event that will yield what you are experiencing. Your neutral line is maintaining voltage, it shouldnt be, and when you flip the main breaker off the shortest path to ground for that voltage is thru the reverse polarity light to the safety ground. Thats the flash you are seeing.<br /><br />Start by checking the polarity of your boats AC. Either use your voltmeter of get one of those inexpensive testers that plugs directly into the outlet.
