Re: Battery Charging Ideas
That TM draws around 35 amps from the battery. So with a 150 AH battery, you should theoretically get 4.3 hours of run-time at full throttle (150 divided by 35).<br />Now, there's all sorts of qualifications to this. First, deep cycle batteries like to be discharged at a particulair rate. Go outside this rate and the Amp-Hours will suffer. The quoted 150AH is probably at the battery's 20 hour discharge rate - in other words, with a 7.5 amp draw. What will it be if you do it in 4 hours with your trolling motor? Probably around 100AH.<br />Second, to make your deep cycle batteries last longer it's best not to discharge them past 50% of their capacity. They are capable of doing that, but they degrade far more quickly when you go much beyond that.<br />So, if you want to be nice to your battery, you will only use 50 AH of that 150AH (well, really 100AH) capacity. Which means just under 1 and 1/2 hours operation at full throttle.<br /><br />Now, if you operated at 1/2 throttle, your current draw is only around 18 amps. Since you're discharging the battery slower now, it'll effectively become a 115AH battery. So, using 50% of that (57AH) you get a little over 3 hours of operation (57 / 18). If you were to completely discharged the battery (115 / 18), you would get almost 6.4 hours of run-time. <br /><br />Hope that helps you understand it a bit!
