Re: buying a fish locator
Bought a Cuda 168 last year.<br />Works great and holds bottom readings up to 25+mph.<br />As with all transducers, proper mounting location is vital. You may want to test it before doing a permanent installation.<br /><br />Cuda 128 is about the same, but has less lines of resolution on the screen.<br />Both model have water temp sensors in the transducer.<br /><br />The only thing I don't like about mine, is that the display does not swivel left and right.<br /><br />If you are going to use it to actually locate fish, not just bottom depth, structure, and weed lines, then take the time to learn to use it in the "arches" mode.
