Re: Instrument Dash on 77 Glastron-Carlson
Wow, that is some helm! Your job looks a little more complicated than mine and it looks great already. I had to do the overlay to cover up my repairs. <br /><br />I don't think you can bend this stuff over such a sharp angle as on the top of your helm where tha gauges are. It would pop off because no matter how much you bend it, it straightens out the instant you let go. I do not know if you could soften it and bend it? You might need three pieces, or two, you could do the top and bottom only where the gauges are and skip the center section where the ashtray is mounted. <br /><br />As far as the lower helm section I would remove everything, cut a piece to overlay the area, then mock it up and trace the dash openings onto the back of the sheet from behind the helm. Trace the shapes onto some pieces of 1/4 inch plywood and cut them out, these are the backing for your large openings, they will provide plenty of stiffness. Epoxy them to the back of the sheet and epoxy the assembly to the helm. Then cut new holes, or cut them before you mount the sheet to the helm if it makes more sense to. Consider how you will address the edges of the sheet though. I didn't do any more than sand mine smooth and smear a film of epoxy on the edge to seal it. it looks OK but I wish I'd have beveled it or colored it or something.<br /><br />The carbon fiber will be plenty sturdy even if you just screw it to the helm, maybe that's what you are doing on the bottom, replacing individual pieces? This stuff is strong as heck and when bonded to a wood backing it becomes very very stiff. Laminates of this kind are used in racing sailboats, spaceships and battle-bots, it should look cool in your boat too! By the way, I don't think I'd use silver on the top sections because of glare. And if it were my boat I'd just use three bands of it, one for the top gauges, one for the lower gauges and one for the steering area. Or maybe just do the steering area and leave the top as is, because it really is nice looking and original looking except for the new instruments, which are so nice I wouldn't want to put anything up there that competes with them. I wanted to put it all over the boat to at first but I think you can easily over do it with details like this, it becomes a theme kind of. The bottom though looks like mine did, lots of random holes. I think it would look best if you only did the bottom but that's me. Either way I would recommend you ask the supplier if they can send you some samples so you can get a feel for it.<br /><br />Your boat looks fantastic, Ralph, do you have a link to more pictures?
