Re: motor mount lag bolts
If you've got trouble with one, you probably have trouble brewing with more. Were the lags stainless steel? Could you detect signifigant moisture?<br /><br />I would re-drill to accept larger and longer stainless bolts. Pay close attention the the material coming out as you drill. If it remains to be rotten, you've got a project on your hands. If not, I would get some CPES, pour it down the holes, letting it drink as much as it will. Let it cure for a couple of days and run your bolts down. I would seal them with 3M 5200. If the problem was nothing more than water seeping into the holes, the above should remedy everything. I don't have much faith in Get Rot. It would not help anyway, if all the wood was rotten. It might help hold things in place for cosmetics but not for lag bolts.
