Re: marine plywood- treated or not
Basically what the article says is you must use marine grade pressure treated ply that has been redried. Lumber yard pressure treated is a bad thing because it has not been redried. I wonder if they used poly or epoxy in their tests. I assume it was poly, since boats are usually not manufactured with epoxy. Kinda disproves that "Poly is not a glue and does not bond with wood" statment that gets thrown around on here once in awhile...
