I have a 1995 190 Horizon Four Winns. . The engine is a cobra 5.0 ford with a OMC outdrive. I have a water leak coming into the the engine compartment. It appears that the water is coming in from the Transom area. Is there a seal between the Transom and the outside of the boat? How would I test to see if it is this seal? Is the Transom difficult to remove? If its not the seal leaking how can I check the transom to see if it is bad? I can look and can see the water running down from area up above the drain plug where outdrive in connected. It leaks when boat is put in the water without the engine running. Would the engine and out drive have to be removed to check transom? Thanks
