walleyehed
- Jun 29, 2003
- 6,767
I doubt that's an issue. Lund has many of their boats with built-in tanks in the front with 10-15ft of fuel line. It's not an issue and if it were truly restricting it, it would have burnt a hole in a piston by now. It may surge if a restriction exists, but it won't run at a constant rpm if restricted.
Chris, fuel pump/s starting to get weak will cause the engine to want to fall on it's face when you pour the power to it such as getting on plane almost like it's going to die.
