g0nef1sshn
- Feb 24, 2015
- 1,291
Ill get the ser number later. But I have a 92 I believe 2 stroke 4 cyl 40 hp Merc. Motor ran great prior to the opening day of duck season. Then one they way back to the ramp I hit something going 1/2 to 3/4 throttle under the water. It felt fine and it ran fine until I idled down to look at another spot. Then it DIED on me. It would start then sputter immediately. Then it wouldn't start at all. After drifting in the current for a long time I gave it a few more goes and it started! I let it just idle for ten mins or so and put it into gear. It idled foward for awhile but with the slightest throttle it wanted to die again. So I idled to miles back to the ramp and shut her down.
That was late Nov. Fast forward to last weekend and I get the boat over to a recommended guy from a friend for a look see. He couldnt get it to even start. Which Im not surprised. (From talking around I may have messed the timing up?) So he pulled the spark plugs and said one was dirty like one cylinder wasnt firing and the others looked fine.
Question is... If I have had the boat in the water 4 times and it ran fine/WOT/on plane, could it do that with one CYL down? OR: could hitting something in the water affect the switch box (which he is suggesting as to why the plug is dirty and cylinder not firing?). Or was it my repeated trying to restart the engine after hitting something that could have fried the box?
Upon reading into it I am seeing switch box/triggers/stators all kinda in the same grouping of troubleshooting. Any thoughts?
This was the last ride a week before the incident...
https://www.youtube.com/watch?v=i459jbe2rXI
