stevepamboukes
- Jul 22, 2016
- 52
Hello all!
Thanks for your help so far - i got started here with my first post (link below) and it was a huge help. Now ive gotten a lot of enjoyment out of this rig, and my engine has been pretty darn reliable! A good performer too!
Yesterday, though, may have been the last day of the season for me:
I was pulling in to dock, shifting between F and R quite a bit to jockey around and navigate a nasty eddy. All of the sudden, reverse stopped working. I was able to dock safely, and eventually navigate back home... but needless to say I'm a little disappointed about my transmission problems!
When it first happened, I had forward, neutral, and NO reverse. I checked out the wiring as best I could on the fly, opened the selectric shift box, checked wires, all looked pretty good as far as I could see. Then, kind of out of no where, reverse started putting me into forward. Not really an improvement, but I was just sort of happy that at least something was going on in there. Maybe not a good thing at all. I was able to get home nonetheless and the engine seemed to run fine in forward.
So I still have much to research on this problem, I expect I'll check the wiring again, but after that I may need to get into the LU/transmission situation and see whats going on in there. I figured I would post here first and see if anyone had suggestions for obvious failure modes that would lead to this. Speaking of wiring, does anyone have a description of the selectric shifter wiring configuration? Ie, which wire does what for F, N, and R? That will be the first place to start...
