FreeBeeTony
- May 15, 2002
- 3,991
Not quite what I had in mind.........<br /><br />Slowly bought up the throttle, backfired through the carb and lost power. I backed off the throttle, seemed to idle ok. Tried again, same result. tried again and seemed to clear out. Thought maybe a clog in the carb?<br /><br />Was able to throttle up to ~3600RPM, seemed strong, then it almost made the same noise as the original problem except now at a higher RPM and an occasional backfire through the carb.<br /><br />I am going to take it out again and run the test I did at the end of last season to see if I am still loosing a cylinder.<br /><br />Hope the backfire indicates something else. I am also going to change the fuel filter.
