Re: '85 OMC 3.0L/Stringer Jumps in/out of gear
Here's how to properly adjust the shift cable for your Stringer. Do it either in the water or in the drive with muffs.<br /><br />Go to the shift adapter box and disengage the cable coming from the helm. Start the engine and let it idle down. Idle should be around 650 RPMs. <br /><br />Now to check the cable adjustment...<br /><br />After the motor is properly idling, manually push the lever on the shift adapter assembly left. Very slowly, Listen for the forward gear to begin to engage. Stop! With a marker or pencil, mark the dial at the top of the lever. Now pull it down and do the same thing going into reverse gear. Mark the dial above the lever. You can shut off the engine now.<br /><br />Now look at the two marks on the dial and split the distance between the two, using the dial gauge as a reference. Place a mark on the dial at that center point. Push the lever to that center mark. Now place the cable back on the shift lever. Making sure your throttle is in neutral, check the alignment of the shift lever. <br /><br />If necessary, use the cable adjustment collar located at the shift adapter box to align the shift lever to the center mark you made.<br /><br />That adjusts the shift cable properly for neutral balance, just in case it's out of alignment.<br /><br />If the engine is idled up too high (over 700) then that could be the cause of your gear failure. That is one of, if not the biggest causes of premature clutch dog / gear failure in Stringers and Cobra drives.
