Kevin Burchett
- Mar 28, 2006
- 2
1995 19' Spectrum boat. Mercruiser 3.0LX 140hp. Alpha One. Cant find a similar post anywhere... Trailer button doesn't work, Trim Up button doesnt work. Trim Down works OK. The trailer button dosnt really "push in" like you would expect a button to do. Popping the rubber hood off, I see it is just a copper cone over 2 points. I connected the points with a screwdriver and blew a fuse(replaced it), how in the world does that button work? Anyway, I replaced the up cellenoid no difference. (Oddly the green wire is "the down" & blue is "the up".) I switched them on the down cellenoid (as a test)and the unit would rise and while pushing the down button,(thats why I thought the up cellenoid was bad). // Inspected the port and starboard trim switches, both seem fine, well lubed and supple wires. // The boat does not have a dashboard gauge. // I did lower the tounge on the trailer so the unit could lower to max, no change. // Boat sat outside uncovered for 3 years (repo). Boat in good shape, no sign of abuse or home mechanics.// New battery. // Checked wiring in throttle assembly, nothing brittle or loose. // I see alot of posts like " up botton not working trailer button is". I have not seen this scenario or is it offered in my Shop Manual. Please help, very greatfull for your time.
