Rick Rickoff
- Jun 21, 2016
- 6
I purchased a used 1988 Four Winns Freedom 160 boat having an inline 4 cylinder engine that is mated to a Cobra outdrive. This is not the original 3.0 litre engine that came with the boat, and I am having difficulty in determining exactly what this engine is. It does appear to be a GM marine engine, and I did find identifying numbers stamped into the block adjacent to the distributor, but so far haven't been able to find listings by GM, OMC, or even Mercruiser, which contain these numbers. There are two rows of numbers found on the block, and the top row reads "M11118RB" while the row below that reads "T1032416." I am assuming that the top number is the engine model number while the lower number is probably the engine serial number. From what I have been able to find out, it looks as though the last 3 numbers (8RB) of the model number are descriptive of the last digit of the model year followed by a two alpha character code designation which relates to the engine displacement and available options. So, this could be a 1988, a 1998, or a 2008 engine, which doesn't narrow things down very much, and I can't find the "RB" engine designation in any listings which I have been able to locate. I did find RA, RF, RJ, RM, RN, RP, and RX codes in a May 2002 Mercruiser service bulletin pdf, but no "RB" code, and the OMC engine code listings I have found don't match up either. I'm hoping that someone can point me to other possible listings where I can find a match. Thanks in advance for any help or suggestions.
