Re: yammar diesels turbos
Originally posted by rdemay:<br /> thick black that last abot 15 -20 min befor it calms down..
I agree with both rodbolt and searay on the turbos, but I can imagine a scenario where they spin slightly faster when they get good and hot. I also agree that black smoke is too much fuel for the available air.<br /><br />What I don't understand is why it goes on for such a long time and gets better. I would think that they would be fully warmed up surely by ten minutes, probably less than five. If it was 15 - 20 seconds I would say that it might be nothing or the fuel air ratio control which may have a diaphragm that is bad, but I don't know Yanmars. After it clears up what happens if you back out of the throttles all of the way to idle speed and then get back into the throttles and back to cruise? Does it take another 15 - 20 minutes?<br /><br />I am also confused about it happening with both engines . . . Which gets back to the injectors question that searay asked. Did they do this before they were changed? Need more history. Have they ever been right? Also, does the boat pick up any speed when the smoke starts to clear?<br /><br />If your engine room is clean I would try running them without the aircleaners for a short period, just to get some info to work from . . . I don't worry about contaminted air on the water, but if there is something loose they can suck in, they will
<br /><br />Oh and I just thought of something else. Maybe air leaking between the turbos and the intake? I could imagine some sealing rings tightening up too. Do they sound any different when it clears? i.e. maybe the turbo whine changing. You're not running these 100% I bet, so I don't understand why they would overfuel, that's why I am thinking air.
