I have 1992 merc 5.7L inboards. Have always used staight 40 wt oil. Dealer convinced me to switch to merc25W40 oil. Oil pressure is now 45psi at idle, and pegs the meter when I rev the engine in neutral.<br /><br />Merc says the oil should be fine, but that I probably have too much oil in them. Manual says it should take 5 1/2 quarts of oil, but to get a full reading on the dipstick it takes about 7 quarts. Does merc make different size oilpans on these? The previous owner mentioned something about a deep pan, and he always used about 6 1/2 to 7 quarts to fill. <br /><br />Will likely go back to straight 40 weight cause I didn't have this problem using it. But the question still remains: Do you fill to full mark on dipstick, or what it says in the manual?
