Re: Harmonic balancer..
anita, I would nt expect to get over 5000 rpm with the props you tried. If you did, you would have been under propped. You just need to take the porp that got you close to 5000 and stick with it even if you dont like the top end. I am pretty sure from the postings and the size weight of the boat you must have, the reason you toasted your first engine was over load detonation. Stick with the 21 pitch that it "swings just fine" and dont put a bigger prop. My 350 will spin a 14 1/2x21 and hit 4600 rpm and thats about it. f_in above is showing almost the same thing and we both have smaller boats than you.<br /><br />By the way, I am going to be on the Chain this weekend. If you got a cell or at least a boat name I'll see if I can look you up while I am out there. I have a second house on Lake Catherine and I used to live a hundred yards off of that channel between Petite and Fox right where you guys tie up.<br /><br />PS, if you want to send the cell# by email it is more private it is vatter41 at aol dot com
