Bewildered4toolong
- Jul 16, 2005
- 3
I have a 1978 Fiberform Cougar , a 470 mercruiser in it, The alternator belt is really trouble. The belt slips, smokes, Iv seen the alternator pulley get soooo hot it actually has melted a belt in two pieces at the Alt Pully. I have replaced the alt, used new belts, cleaned the wire connections and even installed a larger ground, to no avail... =( Just how tight should this belt be? This is also a replacement kit for the original Merc alt, and everything is installed correctly and the pulleys are aligned with one another. The Engine temp is running in its operating range, and the boat really runs extremely well except for this one problem. The belt and pully get hot, smoke and the belt fails, it really is driving me BatGuano!!! Any Suggestions?
